m42 exhaust
Darragh
Thu Aug 05, 2010 5:42 pm
hi!
just wondering if many m42 owners have had their exhaust manifold crack between the flanges and the pipe. mine seems to have cracks on 3 of the pipes.
im getting an exhaust made up for the car next week and thought that whilst its apart i was going to weld it all up again. but this involves unbolting the manifold off the head. im just a bit worried that bolts might start snapping off due to corrosion ect, or are these normally ok as long as i use plenty of penetrating oil?
alync205
Fri Aug 06, 2010 12:00 am
It seems to be a common enough problem for the manifolds on the M42 to leak there allright.I would say you would want to bolt the manifold to something when you are welding it as the heat from weling it could warp the manifold and it wont seal against the head.
Darragh
Fri Aug 06, 2010 12:49 am
very good point man, i'll be sure to do that.
with a 205 you must be used to cracking manifolds too! great fun cars! i miss my old one!
