Changing the Rocker cover, one simple question!
Adam318i
Post Sat Sep 17, 2005 12:17 pm
right ive got an M40 and im changing the Rocker cover to a black/polished one.
It looks easy enough, just the bolts on top of it, and then a pipe going into one of the corners near the throttle body.
Do i just pull on this pipe and is it going to piss out water?
Or does coolant only flow thru it when the eigine is up to temperature or running?
Cheers Adam
I love my Rice!
Post Sat Sep 17, 2005 2:08 pm
Only pipe going into a M40 rocker cover is a breather pipe, so no water will come out.
Engine won't idle properly if this pipe is off or leaking.
ZS
Post Sat Sep 17, 2005 2:40 pm
If there's coolant going into the rocker cover then there's something very, very wrong with your engine.
Once driven, forever smitten.
Direct injection, turboed, intercooled, 16 valves giving a whopping 48.5hp/litre!! :(
Adam318i
Post Sun Sep 18, 2005 11:02 am
Yup its the breather pipe, cheers Brian :thumb:
Just wasnt sure what was going to be flowing through it.
Adam
I love my Rice!
