any chance u lot may have a pic of where it is sat and what it should look like...
ill explain in time
Trying to read and understand that this early on a Saturday has given me a headache.johnono wrote:is Non-cat a lambda free system then?
mine is non cat and the realoem shows no lambda on a non cat system so...
is there no lambda on non cat cars?
Yes, if you remove the Cat from a Cat equipped car it will run fine.johnono wrote:so could a cat equipped car run without the cat completely?
The lambda monitors the unburnt oxygen in the exhaust gas to keep the air/fuel ratio as close to 14.7:1 as possible, as this is the optimum air/fuel ratio for combustion (stoichiometric air/fuel ratio). This keeps the engine running at a balanced point between power, efficiency and a good level of emissions.Brianmoooore wrote:Purpose of the lambda sensor is to protect the cat against overfuelling and consequent damage, so no cat, no need for a lambda sensor.
Not sure on that one, TBH Ive never looked into it. Something is adjustable but I couldnt tell you what, sorry.johnono wrote: is the % level adjustable from the small screw on the afm?
Thats cool, I was told on here somewhere that there was a difference between the ECUs - I stand corrected.ant wrote: the 02 sensor removal does not require the ECU to be replaced, they all have provision to run with or without, even the 073 type on chromie cars is Cat prepared
