e36 rear brake pipes
psychochild187
Post Sat Jul 24, 2010 10:06 pm
e36 4 door car failed mot on the rear brake pipes. the ones that go over the tank and to the flexi hose . on both sides
just a quick price question really . on how much it may cost to put right.
Post Sat Jul 24, 2010 10:26 pm
To do it properly the tank needs to come out so that means exhaust, heat sheilds and prop so the labour time is what makes it expensive. The pipes dont cost much. Reckon on about 4hrs labour.
At the BMW dealer i work at its £50 ph+VAT for cars over ten years old.
psychochild187
Post Sun Jul 25, 2010 12:43 pm
ive been given the same responce by somewhere else . its a horrid job from whats been said.
so about 200 im looking at a indy
Post Sun Jul 25, 2010 1:13 pm
you don't have to drop the tank, i did mine by undoing the straps and this drops the tank enough for you to have access.
maxfield
Post Sun Jul 25, 2010 1:15 pm
Agree with Simon. I did some once, took me an hour, quite an easy job.
Made it a lot easier using the pipes from BMW too.
Post Sun Jul 25, 2010 10:30 pm
Simon13 wrote:you don't have to drop the tank, i did mine by undoing the straps and this drops the tank enough for you to have access.
What pipes did you use?
Post Sun Jul 25, 2010 10:32 pm
maxfield wrote:Agree with Simon. I did some once, took me an hour, quite an easy job.
You used BMW pipes?
So you bent them in exactly the same shape as the originals and routed them in the exact same place and used all the mounting clips?
Andyboy
Alpina Colada
Post Sun Jul 25, 2010 10:36 pm
It's a bastard to do it properly. So I just made up some copper pipes and routed then in an approximate fashion. There aren't many E36's that justify £200 for rear pipes......
Post Sun Jul 25, 2010 10:43 pm
And zoners moan about E30 rear brake pipes Image
Post Sun Jul 25, 2010 10:47 pm
E38/E39 ones are worse still! Not only does the tank and associated crap have to come out, so does the rear axel!
Post Sun Jul 25, 2010 10:55 pm
no i used copper its an e36, i've seen them routed across the exhaust cross member.
Theres only 1 or 2 clipes each side, copper bends nice and easy too! My 328 has no traction so i don't know if that helps
Post Sun Jul 25, 2010 11:00 pm
Simon13 wrote:no i used copper its an e36, i've seen them routed across the exhaust cross member.
If it has ASC there will be two front to rear pipes.
psychochild187
Post Thu Aug 27, 2020 12:52 am
omg ! 10 years ago . i did this job and still remember it and hating the job at the same time and i did drop the tank and renew all lines
