Sound proofing
stulane
Wed Sep 14, 2005 10:29 pm
Hi Guys,
Right, got the m50 in and driving it about daily.
One problem is the amount of noise the engine makes through the bulkhead.
Whats everyone's best advice with sound proofing?
A mate suggested the roofing felt underlay that you put on with a blow torch.
The foam on the bonnet has been removed and some of the sound insulation around the firewall has also been removed and needs to be replaced.
I need a solution if anyone can help.
Thanks,
Stuart
pomebastard
Fri Sep 30, 2005 6:12 pm
You may have to do a bit of research on google.
I recall seeing some special soundproofing material supplied by a company in the US.
www.LozWilson.com/blog
The 4 Oases of Wealth
www.NewbiesInternetMarketingGuide.com LIVE!
Get the BIG Picture Fast
www.PropertyFortunes.com LIVE!
Professional Property Profit Making
Fri Sep 30, 2005 6:34 pm
Can't you get a piece of the original material in from a scrapper? Didn't have any problems with the standard insulation fouling anywhere when I did mine.
Sirnixalot
Sun Oct 02, 2005 12:21 am
dynamat?
pomebastard
Tue Oct 04, 2005 6:56 pm
...that's the stuff try www.dynamat.com
Steviec
Mon Oct 10, 2005 3:52 pm
I used dynamat in my old car (did bass competitions), the best stuff is dynamat xtreme, its very thin and does a very good job at sound proofing. Not sure how well it would cope with the heat from the engine though?
Its also quite expensive, Ԛ£30 a sheet or a bulk pack of 9 sheets costs about Ԛ£190 although im sure I found it for like Ԛ£130 on the web before.
