80 mph @ 6000 rpm in 5th gear
e30121
Wed Jul 07, 2010 8:26 pm
I just bought a manual 1991 320i e30 cabriolet. On the way back i was doing 80 mph (wouldnt go over 80) at 6000 rpm in 5th gear is this normal ?
If not can someone tell me what could be the problem. Previous owner told me the engine had been rebuilt.
By the way im a newbie and dont know much about theese cars.
Wed Jul 07, 2010 8:29 pm
Sounds like you have a 4.27 (or higher!) ratio diff in it or the engine is goosed!
DHFiS
Wed Jul 07, 2010 8:31 pm
Doesnt sound normal. Maybe the diff has been changed to one with the wrong ratio?
PG325
Sure you weren't in 3rd!
e30121
Wed Jul 07, 2010 8:42 pm
definatly not in 3rd
Wed Jul 07, 2010 8:45 pm
has the car been converted from say a 318i to a 325?
e30121
Wed Jul 07, 2010 8:54 pm
Not that im aware of he said rebuild so probably not
psychochild187
Wed Jul 07, 2010 8:57 pm
how fast did you go in 3rd
Wed Jul 07, 2010 9:04 pm
I see 3 possible issues
1- You were in 3rd :)
2- It has had the diff changed to a 4 pot diff
3- the instrument cluster has been changed with a 4 pot one and it has the 4 pot coding plug in still, so the tacho will be over reading - the coding plug is easily changed and if you are not used to 6 pot BMW's then they can sound like they are revving higher than they actually are.
Edit - I suppose the best way of testing theory #3 would be to give it beans in 1st gear, if the tacho goes off the clock then you have the wrong coding plug in, if it hits the rev limiter at about 6500 then it has the correct cluster/ coding plug
bmwowner
Wed Jul 07, 2010 9:05 pm
my 318i (m40) sits at just over 3000rpm at 70 and just over 3500rpm at 80.
the same as my sisters old e36 318i....
StuBeeDoo
Wed Jul 07, 2010 9:07 pm
Even if the car had a 4.45 diff, it would do over 100 mph at 6000rpm in 5th (118mph, to be exact).
Did it sound like it was revving its nuts off?? Just supposing that the car has been fitted with instruments from a 4-cylinder car and the coding plug hasn't been changed, your "6000rpm" would actually be 4000 which should be somewhere near right for a 320i at 80mph.
When you say "wouldnt go over 80" do you mean that you wouldn't drive over 80, or the car wouldn't go any faster than that?
e30121
Wed Jul 07, 2010 9:22 pm
I wouldnt drive it over 80 it was very close to the red line.
Wed Jul 07, 2010 9:26 pm
If the car is still warm, go outside and start it up and give it a big rev up, if the tacho sails past 7k then I would lay money on it having the wrong coding plug due to an instrument cluster change (which would mean the mileage could be suspect)
What revs does it sit at on tickover?
e30121
Wed Jul 07, 2010 9:30 pm
Thanks E30BeemerLad ill try it. it sits at just over 1
vokietis
Wed Jul 07, 2010 9:34 pm
if your diff ratio is 4.45 it should do 80mph in 4th,or 80mph in fifth if your car has dogleg box.
Wed Jul 07, 2010 10:08 pm
e30121 wrote:Thanks E30BeemerLad ill try it. it sits at just over 1
Sounds like maybe you have 4 pot clocks in..
Does it sound like 6k? How far will it rev in 1st?
Wed Jul 07, 2010 10:13 pm
vokietis wrote:if your diff ratio is 4.45 it should do 80mph in 4th,or 80mph in fifth if your car has dogleg box.
325i wont have a dogleg gearbox with 1.1 5th.
vokietis
Wed Jul 07, 2010 10:17 pm
it can have anything fitted,even m50 box
Wed Jul 07, 2010 10:47 pm
vokietis wrote:it can have anything fitted,even m50 box
Yes other gearboxes can fit but its unlikey that it will have one.
Getrag 245 dog leg box's are very thin on the ground in the UK and were only available on pre sept '85 323i's and i think 320i's.
Getrag 265's from the M3/320iS dont fit an M20 unless you use a US spec 325e bell housing.
Again, very unlikely
Wed Jul 07, 2010 11:01 pm
Lockwood dials with chrome rings? :)
bpowell555
Fri Jul 09, 2010 12:43 am
I was getting 5000 revs at 100mph this evening... then I realised I was in 4th :D
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
DavieP
Fri Jul 09, 2010 4:43 am
StuBeeDoo wrote:Just supposing that the car has been fitted with instruments from a 4-cylinder car and the coding plug hasn't been changed, your "6000rpm" would actually be 4000 which should be somewhere near right for a 320i at 80mph.
I drive a 320i auto and @ 80mph in top it is doing around 3400 rpm. Even the 'smooth' B20 engine note becomes a bit intrusive at a true 6K rpm so I doubt that many drivers would happily cruise mile after mile with that racket going on. It has to be a coding plug issue.
Dave in Torquay
Daf318is
Fri Jul 09, 2010 1:48 pm
Something's not right there - that's kit car with bike engine territory! :o
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
kniterider
Fri Jul 09, 2010 2:06 pm
Silly question but does it pull ok? Clutch isn't slipping is it? My old pug was bouncing off the limiter for 15mins solid at 50mph (just) in 5th till I came off the sliproad, droppe a gear and the clutch went bang! Unlickley mind as I'd hope you would notice it.
e30121
Fri Jul 09, 2010 2:32 pm
E30BeemerLad wrote:If the car is still warm, go outside and start it up and give it a big rev up, if the tacho sails past 7k then I would lay money on it having the wrong coding plug due to an instrument cluster change (which would mean the mileage could be suspect)
I just reved it and it went past 7 rpm so i think E30beamerlad is right. Can somone please tell me how to change the coding plug?
