What maintains fuel rail pressure on a stopped M30 engine?
MJJ_ZX6RR
Post Fri Jul 02, 2010 10:44 am
Morning guys,
I have an annoying problem on my M30'd cabby. Starting from cold after leaving the car for 24 hours is fine. Starting it after leaving it a week involves lots of cranking, hugely lumpy idle, a bit of throttle before it settles down to idle smoothly.
My gut feel is the fuel rail pressure is slowly draining away, and as I assume the fuel pump only runs when the engine is cranking, it takes time to build up the fuel pressure again.
There must be a one way valve somewhere I guess. Is that inside the fuel pressure regulator?
Thanks,
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
zaust
Zone day release
Post Fri Jul 02, 2010 10:55 am
There is a form of valve in the fpr, It is worth a try to change it, But have you done the basic plug check/ clean first.
M30 Tech 1 Touring on gas.
MJJ_ZX6RR
Post Fri Jul 02, 2010 11:08 am
zaust wrote:But have you done the basic plug check/ clean first.
Do you mean sparkplugs? I am struggling to imagine what checking those would show.
Cheers,
Martin.
zaust
Zone day release
Post Fri Jul 02, 2010 11:38 am
Yep, Spark plug's. They maybe a bit sooted up and need a brush, Can effect starting in a mannor of ways. Worth a look at the basics first before you start putting your hand in your pocket for elimination.
