Wing mirror dismantling
bdx
Post Fri Jun 25, 2010 6:16 pm
Removed from car, easy.
Want to repaint the aluminium section, dreaded furry aluminium.
How do you get it apart?
(facelift model)
psychochild187
Post Fri Jun 25, 2010 6:27 pm
dunno but wish i knew how to get the dam mirror glass out
davidcorden02
Post Fri Jun 25, 2010 6:32 pm
hi mate underneath the wing mirror theres a little hole in line with the wing mirror glass get a small screwy and flick the white jagged edged then the glass will pop out mate
bdx
Post Fri Jun 25, 2010 7:54 pm
Cheers, worked a treat.
davidcorden02
Post Fri Jun 25, 2010 8:01 pm
not a problem mate
bdx
Post Fri Jun 25, 2010 9:28 pm
Took the glass out and saw the riveted construction.
Its a case of masking up the plastic, grit blasting the aluminium then etch primer it (and filling in the pits).
