m42 running probs
traffman
Fri Jun 18, 2010 4:41 pm
the engine is running so lumpey checked all icv pipes replaced eneyway new gaskets for manifold and still no joy some one please help
pac1982
Fri Jun 18, 2010 4:46 pm
Have you gave it a good service recently?
New plugs, oil & filter, fuel filter, air filter etc etc
BMW's seem to respond really well to a good service
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
traffman
Fri Jun 18, 2010 6:17 pm
yep i brought car 2 weeks ago i have done the following air filter oil filter oil and plugs new water pump thermostat and radiator all new vacum pipes also the gaskets as well new track rod ends lower arms bushes as well . i have cleaned the in let manifold completley its like new i just cant work it out
mc_hawkings24
Sat Jun 19, 2010 11:24 am
Have you checked the coil and leads?
tez180
Sat Jun 19, 2010 11:54 am
Check for air leak on the TB gasket etc too, mine had a small leak there once.
Accord Type R
245 Whp
chrisE318is
Sat Jun 19, 2010 2:20 pm
has your car been chipped? could be cause if so as these run badly with a chip that doesnt suit your ecu firmware.
breaking 2 door dolphin grey tec 2
pm me
DHFiS
Sat Jun 19, 2010 2:24 pm
what rpm does it idle at?
