Engine is in the engine bay hanging on the crane still. Im not sure what to do about the engine mounts ? Can i buy the conversion mounts from anywhere ? Or will any perticular BMW mounts bolt up ???
I wanna use the gearbox from the 5 series also, I've swapped the gear lever lincage's over to shorten it enough. Problem i've got with the gearbox is the rubber doughnut is bigger and wont bolt up to my prop shaft ??? Could get my prop cut and shut. Is this the only way to gt around this ???
Maybe i could of found the information i need on the forum somewhere, ive had a quick look but had no luck.
Thank you for any help people !
