are the metal brackets on the bumper carriers still availible to buy new if so a price for 4 please, if not will the brackets off a standared bumper do the job?
cheers mike
m tech 2 bumper brackets?
mikey325isport
steviebmw
i have rear bumper brackets for an e30
not a chrome i am selling them
mikey325isport
are they the brackets that bolt the tech 2 carriers th the dampers? are they the same if not m tech? if they do fit, how much?
Cotswoldbmw
Hi Mike
the brackets on the carriers are the same, its only the plastics that are differant but i am not sure which brackets you require, if you let me know which ones you require i can let you have an exact quote, you should be able to identify parts on realoem.com
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
mikey325isport
its not on there, its the metal bracket that sits inside the bumper carrier, the bolt goes through it verticaly( through the dampers that stick out of the rear panel ) i think they are bolted inside the carrier by torx bits (6 i think) will it be easier if i take a picture?
many thanks mike
many thanks mike
Cotswoldbmw
Hi Mike
£6.88 for the 2
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 31264
There is a P&P cost of £1.99 on all orders under £20
Brett
£6.88 for the 2
Brett
Cotswold BMW Parts
01242 335365
01242 335365
mikey325isport
i think ill be needing all 4 front and rear, are the front the same as the rear? also art the bolts included or will i need to source those too?
cheers again
mike
cheers again
mike
Cotswoldbmw
Hi Mike
front brackets £9.82 each
rear brackets £6.88 for 2
bolts X14 £9.93 for 14
Please call our Parts Dept. on 01242 257999 and quote 41736
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
