Howdy, ive got a problem with my car it wont start.
I thought the chip was gone in the key but i ordred a new 1 and still no joy,
-the battery is new
-All earths seem tight and good
-wont go on a push start or tow
-and ive power to the ews ecu, main ecu, and transponder ring moduel , Im getting 3ohms across the pins on the transponder ring which seems ok when tested against another one!
anyone got any ideas where i can go now?
Thanks in advance Brian
S50 ews problem
feens
S50B30 E30
Larsen-Racing
B30 or B32?
87 E30M3 RB26DETT
ian332isport
Does the EWS module click when you turn the ignition on ?feens wrote:Howdy, ive got a problem with my car it wont start.
-the battery is new
BAZE30
He got it sorted, both the igintion and the key where busted.
feens
Cheers lads, sorry never said it was an s50b30 oops!! as Baz said it was both the chip in the key and the Tranbsponder ring that were gone, i had power everywhere when i tested it so just tried another ring from an e36 even tho my one didnt show fault on the meter!!
It fired up 1st time with an new ring!!
S50B30 E30
