Leaking Koni sport adjustable shock
charlE30
Thu Jun 03, 2010 3:49 pm
Just a quick one, can you get leaking shocks repaired and is it more cost effective than buying a new replacement? I've heard of people getting shocks re-valved?!?
The shock in question is a rear Koni Sport Adjustable so would be £90 each
Charlie
BMW F31 335d xdrive
charlE30
Fri Jun 04, 2010 8:30 am
Anyone know?
BMW F31 335d xdrive
town325i
Fri Jun 04, 2010 8:43 am
I no Bilstein offer a repair service for there higher quality dampers but it cost nearly as much as a new damper
Raj_p
Sun Jun 06, 2010 2:52 am
charlE30 wrote:Just a quick one, can you get leaking shocks repaired and is it more cost effective than buying a new replacement? I've heard of people getting shocks re-valved?!?
Charlie
Is this through general wear and tear or is it a faulty shock? they offer a life time warranty i think
gareth
Sun Jun 06, 2010 9:09 am
I've just fully rebuilt my Leda coilovers and as far as i know these are similar in principle to the Koni units - however i don't know if the koni's are designed to be opened up after manufacture. Mine have a screw in top cap that uses a peg spanner.
well worthwhile though, mine have unknown mileage / age and had one slightly bent rear piston rod, all 4 piston rods were corroded and pitted, the seals had all failed and they were all leaking due to seal wear (from the pitting) and bearing wear allowing play. it's fair to say they were very old though! :D
£300 later (new bearings, new seals, new pistons - machined to order etc) and they're fully sorted again and ready to be refitted :)
cbv8
Sun Jun 06, 2010 9:48 am
I found to my hooror that a previous owner had fitted odd ones on mine and sealed one was knackered so got to change em both plus spring was broken and i drove it home at 85 i mean 70 mph winkeye like that 8O
Cheers,
Chas.
1988 325i auto Cabriolet
