leaky convertable
jordano
Post Sat Sep 10, 2005 12:50 pm
A new hood is next on my list but in the mean time i have to do with the one i have which has seen better days. There isnt any actuall holes as such but it is leaking through the 'seams' if you will that run down both sides, from what i can tell its like it has stretched and the roof gets very damp but doesnt really drip. just after any ideas to make it last a little longer untill i can get a new one
cheers jonny
Sooty
Post Sat Sep 10, 2005 2:03 pm
A smear of clear, silicone sealant all along the inside of the seams.
It works for the g/f's cab. :)
DemonDaz
Post Sat Sep 10, 2005 4:50 pm
even new ones sometimes leaqk on the seams, I use tent waterproofer, and spray it on thick along the seams
jordano
Post Sun Sep 11, 2005 3:54 pm
it seems to hav rotted away around the seams making the roof kinda perferated,if u luk up at the roof u cn see small pin holes of light cumin through?
AlpineCab
Post Sun Sep 11, 2005 8:32 pm
My roof is exactly the same condition, possibly worse cos I have small splits (just 1cm long) in a couple of places.
Tank tape stuck to the underside of the roof has got me through three additional winters!!!!!!!!!
DaveD
E30Zone Wiki Specialist
Post Mon Sep 12, 2005 2:07 pm
I used silicone saelant on the finger on the underside...works a treat will even seal big splits(i Know)..you can get it in black. Tent waterproofer or even a heavy coating of bumper shine(its only silicone) from poundland will waterproof the canvas...i have tried it all
padi
Post Mon Sep 12, 2005 9:21 pm
i went over all the seems on mine with a thing called stormsure, worked a treat even where the stitching had pulled out...then did the whole hood with autoglyms hood cleaner and then protector brought it up a real treat... 8)
