1. Is there a short term fix for a thermostat that appears to have failed in the closed position? Very Hot top hose, cold bottom hose, heater working fine, water fizzing out of somewhere around the top of the rad when it's been stationary for a while.
2. Is the fan controlled by the thermostat ie. does it engage the coupling somehow? (it failed the newspaper test) Or is that related to question 3...
3. Even when the rad is bubbling away the in car temp gauge only shows just above normal, I assume this is due to the failed thermostat and hot water not getting to the sensor?
4. Or is my diagnosis crap and it's something else entirely?
Cheers in advance
edit: whoops, m40 316i 1989!!
