just a quick conversion question...2.0 -- to 2.5
Ajay_1985
Post Wed May 19, 2010 4:13 pm
hi guys , ive got a 320i convertable with loads of work done to it, resprayed, lowwered, resprayed the whole lot. However its a 2.0 l. Im looking into a conversion but dont know anything about this.. what would i need and where would i go to get it done and how much are we looking at? my engine has done 115000 miles which is good i dont want a engine more than 130000. I dont wanna spend too much. Thinking of 325 engine as they are easy to get hold of and then i can get it declared as a 325...
leeparkes
Post Wed May 19, 2010 11:15 pm
If you want someone to do the swap let us know where you are
2.0 to 2.5 is probably the easiest swap to do.
Chris
Post Sat May 22, 2010 5:32 pm
You wont be able to change the model to a 325i.
You can stick the badge on the back but they wont change the V5. only the engine capacity changes.
Chris
ross2009
Post Wed Jun 02, 2010 6:26 pm
its a straight swap apart from the prop and diff and the ecu :)
