So i drain the oil from the sump, put on new filter, put sump plug back in and just as im tightening it...........CCCCRRRAAACCCKKKK !!!!!! the fcucking thing snaps
So after about 20 mins of pure panic and speaking to a few of my workmates, one of the guys points out that the sump plug is hollow and he's got some tools called "easy-out" wich sort of fit into the hole and you give it a tap and then unscrew
It took me 60 seconds to get it out and luckily for me there is a BMW dealkership at the bottom of the road where i work so i nipped in and Ԛ£1.62p later job done.
Apparently the sump plug had snapped cos it didnt have a washer and i did it up too tight . LESSON LEARNED !!!
This is just one of my many tales of DIY car maintenance. Luckily for me its never too expensive touch wood
Hmmmm what shall i fcuk up next ?
Lee.
