Post
Thu Sep 08, 2005 10:37 am
If you can make the temp stay normal when idling by turning the heater up full, then it is either the viscous unit or the temp sensor that is faulty. However, it is worth changing the thermostat and flushing out the rad just to make sure.
If it overheats while driving along, then it has nothing to do with the viscous fan...Could be the radiator is blocked or the cooling fins on the rad are blocked...take it out (easy job) flush it and blow out the bugs and road tar with an airline...Change the 'stat too, just in case...If it still happens, could be the water pump impeller wearing out....
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
