polished lip
Jonny_92
Post Mon Apr 26, 2010 2:33 pm
has anybody tried polishing the lips on bbs 14 or 15" alloys themselves?
FMH
Post Tue Apr 27, 2010 12:01 am
easy, get various grades of sanding sheets, starting with 80 grit and work your way up
leeparkes
Post Tue Apr 27, 2010 12:33 am
Its easy to do but to keep them shiny is a different story :banghead:
As said work your way up with grades of wet and dry then finish off with a polish, avoid autosol, duraglit etc as you need something to protect from them from everyday filth on the roads and brakedust
Ive gone through loads of polish but ive found this the best, has anti corrosive, easy to use and brings them up like a mirror 8)
JWaller360
Post Tue Apr 27, 2010 12:35 am
What about polishing, then lacquering? Thats what I'm planning when I refurb my BBS
FMH
Post Tue Apr 27, 2010 12:36 am
JWaller360 wrote:What about polishing, then lacquering? Thats what I'm planning when I refurb my BBS
You will loose a bit of shine but they will still stand out.
gra325i
Post Tue Apr 27, 2010 12:41 am
the laquer will just peel and crack within six months..thats what happened to mine..
the nature of laquer is that when spraying it onto paint it should be "wet coated" over the top coat while it is still tacky so that the laquer may adhere with the paint..it just does'nt last on bare metal :(
leeparkes
And they go 'milky' if you chip it when water gets under the lacquer
Edit: must type faster :D
JWaller360
Post Tue Apr 27, 2010 12:43 am
ahh I see.
Bugger.
kam325itouring
Post Thu Apr 29, 2010 9:12 am
i got mine done from a metal polishers.
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
