My speedo is not working
DougieN13
Sun Apr 18, 2010 11:20 am
My speedo has stopped working.
It started being temperamental at first but now doesnt move at all.
Any suggestions?
My cars a F reg 2.5i
LuckyP
Sun Apr 18, 2010 11:32 am
If it has been temperamental then it could be a poor connection somewhere (the speedo is electronic, not mechanical).
I would check the connection on the trigger first as no dismantling is required. It's mounted on the diff cover - easy to get to if you clamber under the back of the car.
Pete.
SDM
Formerly WhiteM3
batteries need replacing, common fault, do a search for it.
Got mine out of storage yesterday (two and a half years), and speedo wasn't working, after hooning it around the batteries started to recharge and it was bouncing all around the place, now it works fine, I was lucky!
Sun Apr 18, 2010 1:11 pm
Could be the fuse.
DHFiS
Sun Apr 18, 2010 1:16 pm
Vibration cracks in the wires from the diff?
KSP_E30
Sun Apr 18, 2010 8:25 pm
what do you need to replace some of the wire connecting to the diff ?? general insulated wire? what Gauge?
Tedswagon
Sun Apr 18, 2010 8:26 pm
Do the rest of the gauges work? fuel, revs, temp?
KSP_E30
Sun Apr 18, 2010 8:35 pm
Tedswagon wrote:Do the rest of the gauges work? fuel, revs, temp?
mine dose (works) just not speedo
LuckyP
Sun Apr 18, 2010 9:04 pm
KSP_E30 wrote:what do you need to replace some of the wire connecting to the diff ?? general insulated wire? what Gauge?
Have you isolated that as the souce of the problem? What tests have you done to confirm this?
If you're sure, then just replace like with like.
jbh
Hartge Crew
Sun Apr 18, 2010 9:14 pm
had this problem recently with a tourer the plug that goes to the diff fell to bits.. I took the wire and plug from a breaker so all was well but I reckon if its the plug you could get off with using female bullet connectors. as for the wire as suggested replace like for like.
Sun Apr 18, 2010 9:30 pm
Headlamp wire and plug from an E30 breaker, or the correct repair lead from BMW.
Don't attempt to repair the existing wire, or use the same wire and plug from a breaker, as the copper in the wire will have changed its physical characteristics as a result of vibrations from the diff, and will have become brittle.
