318is suspension lowering
6cyl springs are a no no as the spring rate will be too high at the front so you wont get the correct lowered affect. If your just going for springs then any 4 pot ones will do but if you do go for a full spring/shock package you'll need 318is specific stuff as you have the 51mm front struts normally found on 325's
HTH
Charlie
HTH
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
The iS is about 15mm lower than a standard car so a spring that lowers a standard 318i by 35mm will lower your iS by 20. If you lower your iS by much more than that I would expect the front lip to be quite easy to catch on uneven ground.
