Quick m52 oil seperator question!
Cook318IS
Post Mon Apr 12, 2010 5:00 pm
Can I run the m52 oil seperator into an m50 maf inlet elbow?[/list]
nickso
Post Mon Apr 12, 2010 6:56 pm
you mean the diaphragm side?
'88 e30 328i M52 track bint.
Cook318IS
Post Mon Apr 12, 2010 6:59 pm
Yeah the bottom bit - the outlet
Post Mon Apr 12, 2010 7:00 pm
The vacuum side yes, but not the oil drain side :)
nickso
Post Mon Apr 12, 2010 7:05 pm
it wouldnt work even if you wanted to do it that way. oil doesnt drain upwards :D
bearing in mind ive not tested mine yet as the lump is still sitting the garage floor, the easiest way i found was to just put a tee into the m50 dipstick.
