springs
nidul
Templ8e30
If you are swapping the complete front struts and rear arms and/or subframe then yes it will.
If your cab has rear disc brakes (99% certain they all are) then there's no advantage to fitting sport parts to the rear. The sport has standard rear arms and subframe.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
fowler
- Boost Junkie
hello matte they will fit if you take the whole strut for the fronts and change the rear shocks will lower the car about 15mm all round
Richy325iTouring
willbe more on the rear as the cab is heavyer
fowler
- Boost Junkie
richy have done this on my cab and it was bout 17 mm at the back
