Annoyign Idle problem tried everything PLEASE HELP!!
Dan318-is
Post Fri Sep 02, 2005 6:40 pm
hi,
i recently cleaned my inlet manifold, and so replaced the inlet manifold gasket, and both throttle body gaskets
i have also cleaned my ICV with carb cleaner
i have sealed/ replaced all my vacuum hoses and sprayed WD40 on them while the engine is running to see if the engine changes note
i installed a viper chip, and then reinstalled the normal chip
and my car still "hunts" between 500-1100 rpm and sometimes even stalls!!
what the hell is going on!!!
Templ8e30
Post Sat Sep 03, 2005 5:01 am
Try a different ICV.
I had this when I converted a 318i cab to 2.5 power, idling it would hunt between 500 and 1500rpm then die and wouldnt start again for a few minutes. Tried a spare ICV and it went away.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
SVBMW
Post Fri Sep 16, 2005 1:03 pm
Temple8e30 wrote:-
What he said.
I bu%%$rd about for ages cleaning the ICV before I gave up and bought a new one
Sorted now
Hyperion
Post Fri Sep 16, 2005 1:23 pm
I also had a strange idling problem with my auto. If the ICV is the cause, where about is it situated??
