I'm thinking about buying a 316i auto to do an M52 manual conversion, Kos said this makes things more difficult?
Could anyone elaborate for me?
316i auto to M52 manual
ross_jsy
well you will need to swap the struts over to the larger 51mm struts off 325's, tourings, cabs or 318is' and also swap out the rear for disc brakes
NomNomNom
How hard is it to change the pedal box?
When you say struts, what do you mean, since i'll be buying new shocks/springs anyway or is the mounting different?
ross_jsy
Front suspension, the legs as it were
If the shell is in good condition fitting the better front and rear suspension/brake parts is not the end of the world, an extra £100 worth of parts is all it is
- Homo Hair
It is slightly more effort, but nothing harder than an engine swap itself
