bloody lsd
slideways
Thu Sep 01, 2005 9:11 pm
right i bought the lsd clutches off motronic in the uk and proceded to fit them (got the crownwheel out without removin the diff casing :D )
problem is the two small clutch like washers on the outside (at either end of the assy) didn't look to healthy but the ones in the kit were different. grrr
putt all back together and every thing was sideways smiles for a wee while, but not the dirty b has started to act up again. prob is.. if you were tryin to do a one point turn it will bite at first and the only spin one wheel.... what is i gonna do??
Ant
Retired Team Member
Retired Team Member
Thu Sep 01, 2005 9:19 pm
sounds like the preload is set wrong, perhaps the washers are intended to act as thrust bearings
