injectors
oo7
Post Fri Mar 19, 2010 7:48 pm
Guys i have been offered a set of 24lb injectors for my turbo conversion are these worth having or should i be getting larger ones than these car will be running about 250-300bhp thanks
Gunni
Post Fri Mar 19, 2010 10:36 pm
Larger ones
Gunni
@ 2012 VEMS group buy !!
AlpineAde
Post Fri Mar 19, 2010 11:03 pm
Don't the boosted guys run injectors in the 30lb and larger category?
Gunni
Post Fri Mar 19, 2010 11:30 pm
I´d always go 42lbs or bigger, Cause you´ll always want to boost more.
Gunni
oo7
Post Sat Mar 20, 2010 5:21 pm
Thanks guys been doing a bit of reading and 24lb are only good for running turbo on standard ecu if running stand alone should be at lest 34lb thanks again for the info :wink:
