smashed the sump off the e30
LagunaE30
Fri Mar 19, 2010 9:34 am
ok, as the title reads i was driving home from a friends house yesterday in the rain, took a right turn a bit too optimistically the back swung out and i smashed straight into a kerb.
there was no body damage at all, however the car did jump up onto the kerb and the only thing that stopped it was the sump which smashed into about 500 pieces all over the road, as well as this the oil pick up was cracked right off and the engine turned off straight away.
i tried to turn it over just to see if it has any life going to it but it doesnt want to do anything, not even turn.
i've left the car on the side of the road and am going to pick it up today and inspect the damage further, really am gutted, will get some pics of the bottom of the engine up here later and hopefully some of you guys can see what ive fecked and give me some advice as to what needs fixing, it was too dark yesterday to tell anything.
thanks, fozz
Fri Mar 19, 2010 9:44 am
unlucky Fozz :oops:
good luck with it,i hope it's not terminal.
LagunaE30
Fri Mar 19, 2010 9:50 am
yeah im hoping its not terminal either, the worst thing is i just had the clutch done yesterday at a cost of £280, what a bummer
Fri Mar 19, 2010 9:56 am
what engine is it?
sorry but i don't read every thread.
DHFiS
Fri Mar 19, 2010 9:57 am
Similar thing happened to me. A second hand sump isnt expensive - I got one from Chris W.
ross_jsy
Fri Mar 19, 2010 10:24 am
i have a sump here if its not terminal (if its an m20)
also got a bottom end if you need further bits
LagunaE30
Fri Mar 19, 2010 12:03 pm
yeh, im goin to go down to the car today and inspect it further thanks for the offer ross ill get back to you on that.
SHAZ325iSPORT
Fri Mar 19, 2010 12:12 pm
you need to slow down mate when you driving,lol
£280 for a clutch,i swear i qouted you cheaper 8O
let me know what the damage is,if you trid to turn it over after the oil had leaked out then you might of done some damage to the engine,sorry.
you should of left it mate,when you see oil leaking or leaked out never try turning the engine over.
LagunaE30
Fri Mar 19, 2010 3:36 pm
lol, shaz i paid the guy a 100 to fit it, the clutch cost me 130 and i spent 50 on the clutch slave and master cylinder.
the engine turned off straight away and when i turned the key nothing happened at all it didnt turn so i couldnt have done any damage (hopefully) no doubt ill be at the garage soon mate getting it towed back later so expect a phonecall tomorrow.
E30star
Fri Mar 19, 2010 4:18 pm
What engine is it?
I know someone who can make taller engine mounts for the M42 (and potentially all other engines). I had them fitted to mine and the car was great - engine vibration was high, until I put a piece of rubber sheet between the mount and the engine, then it was fine day to day. And the centre bearing on the prop was fine too, not a single problem!
rix313
Fri Mar 19, 2010 7:38 pm
Would it not be better to fit a sump gaurd rather than raise the heaviest thing in the car?
oomz1975
Fri Mar 19, 2010 7:51 pm
This happened to me years ago in a 318i coupe, hit black ice & the car went on to the corner of a really high kerb.
Ripped off the front spoiler & took out the bottom half of the sump.
The engine was still running so I managed to drive home (2 miles away, through heavy traffic, although I had the hazards on & ran every red light in Wembley) 8O
Luckily no major damage was done apart from having to replace the sump.
chinchilla
Fri Mar 19, 2010 8:03 pm
alot of people smashing sumps recently! im scared to lower my 318i now :(
ross_jsy
Fri Mar 19, 2010 8:21 pm
well mine is lowered 60mm and gets driven very hard. when i pulled the m20 out, the sump didnt have a single mark on it
chinchilla
Fri Mar 19, 2010 8:25 pm
m40 sumps are deeper :(
ross_jsy
Fri Mar 19, 2010 8:40 pm
ah that will be it then!
another reason 6 pots are better :wink:
chinchilla
Fri Mar 19, 2010 9:11 pm
indeed! one day i guess winkeye
