Is this likely to be a knackered master cylinder or ABS pump or both ? which should I be replacing first ?
Its definately not air in the system as we spent a lot of time making sure that the system is fully bled through with new fluid.
The pedal goes about halfway down before any braking effect takes place - I know that the new disks and pads will take a while to bed in but they really should start to bite nearer the top of the pedal travel than they do.
What I don't want to do is spend money replacing the wrong bits so any help as to the most likely cause would be appreciated
