PAS v manual steering
rix313
Post Sat Mar 06, 2010 10:31 pm
My PAS rack is leaking fluid so it need's changing.
I've been looking at getting a reconditioned E30 PAS rack but I have been wondering about fitting a manual steering rack?
Any one have experience with a manual rack on a track car?
(not currently interested in an E36 conversion before any one brings it up :) )
AdamGardner
Post Sat Mar 06, 2010 10:40 pm
I have a manual rack that was fitted to a 318, always thought it was nicely weighted when going fast.
jbh
Hartge Crew
Post Sat Mar 06, 2010 10:42 pm
I had manual sterring on my old tech1 and i used it as a daily and tbh i preffer it. more feedback through the wheel extra. ill be fitting the manual rack to the current project.
rix313
Post Sat Mar 06, 2010 10:45 pm
That's interesting :)
Been thinking about it and removing the pump and associated pipes would help keep the weight down and it's one less thing to leak!
Look forward to hearing other peoples veiws.
UweM3
Post Sun Mar 07, 2010 8:16 am
compare the "speed" of the rack before you fit a manual. You don't want to end up with more turns lock to lock than your PS assisted one.
Some people run the PS rack without pump, but I am not a fan of this.
RPM
Post Sun Mar 07, 2010 12:22 pm
I run a manual rack, it has a slightly worse lock to lock than a PAS rack
I'd say most of the PBMW grid run PAS racks with the pipes looped or the holes welded up, not heard of any issues but if you dont do it correctly you can get a lock in it
I went for the manual vs the conversion as it was easy, and designed to be just that, a manual rack.
gareth
Post Sun Mar 07, 2010 12:31 pm
TAS (iirc) used to do a manual quickrack for E30's. i'm not sure how this compares to E36 or Z3 racks but it might be worth a look?
rix313
Post Sun Mar 07, 2010 6:00 pm
Is that a member or a company Gareth :D?
gareth
Post Sun Mar 07, 2010 11:50 pm
the are (or rather were) a company. they've gone bust.
the racks used to be listed in the rally design catalogue iirc - maybe they will be able to give you a pointer?
rix313
Post Mon Mar 08, 2010 7:51 pm
Rally design offer som Escort ones so might be worth an email cheers mate.
Apparently Quaife do quick rack conversions, sent them an email for a quote.
