Bleedin(g) brakes - Seized bleed valve
fieldl
Sat Mar 06, 2010 7:09 pm
Went to replace the brake fluid today only problem faced was the fact that the rear offside valve has seized solid typical first one to do too. Trying to free it off just led to it getting less and less nut shaped. So I will order a replacement (maybe two) just in case.
Just to check, what happens when I remove the valve? Anything in particular I need to be aware of?
I presume it just unscrews eventually.
fieldl
Sat Mar 06, 2010 7:20 pm
Oh and another question anyone know what colour RBF600 is supposed to be?
fieldl
Sat Mar 06, 2010 7:32 pm
34111153197 thats the part number
For my reference so I can order the parts ;)
Daf318is
Sat Mar 06, 2010 7:48 pm
Just be carefull - I've snapped one off in the past and then you're in trouble!
I ended up drilling it out with a much bigger hole, fitting a stud to the new "big hole" tapping that and re-fitting a new bleed screw!
I could've bought a S/H caliper.. but that would've been too easy :roll:
Soak it in WD40 for 24hours before you try and shift it again - perhaps a little bit of heat to free it :)
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Sat Mar 06, 2010 8:14 pm
Blowtorch it before you start trying to unscrew the thing, bleed screws are now £5 from the skanking dealers :evil: Good job I have a wire wheel to clean the old ones up
Daf318is
Sun Mar 07, 2010 1:51 pm
DanThe wrote:Blowtorch it before you start trying to unscrew the thing, bleed screws are now £5 from the skanking dealers :evil: Good job I have a wire wheel to clean the old ones up
Five quid? It's only a ruddy bolt with a hole in it really! 8O
fieldl
Sun Mar 07, 2010 8:01 pm
£5 is a bit of a mickey take isn't it! oh well.
They are soaking in WD40 so will have a crack at them next weekend and see how it goes.
Thanks all :)
Daf318is
Sun Mar 07, 2010 8:18 pm
fieldl wrote:£5 is a bit of a mickey take isn't it! oh well.
Thanks all :)
Keep giving them a daily squirt of WD 'till next weekend - that should free them up a bit :)
fieldl
Mon Mar 08, 2010 4:17 pm
£5.10 for a valve :eek:
Will have it tomorrow
