oil catch tank
steve_k
Post Sun Feb 28, 2010 3:23 pm
i think this is in the right section but if not mods feel free to move it.
i've been looking at the oil catch tanks on rar sport & a few i've seen on ebay & i was wondering if some one on here could explain the theory behind them for me?
are they any good?? or a waste of money??
help me out here please folks.
e30den
Post Sun Feb 28, 2010 3:42 pm
for a standard road car i would give it a miss as there are no gains to be had.
the oil fumes or mist is sucked from the top of the rocker cover thru a rubber
tube into the inlet manifold and burnt along with the air and fuel mix basically.
in theory the oil mist is diluting the fuel mixture. i am sure some one will along
with the pro's and con's
steve_k
Post Sun Feb 28, 2010 3:47 pm
thanks for that but my engine is not totaly standard :)
it's got a 270dg fast road cam, bbtb, 6 branch exhaust manifold, chipped ecu, pipercross viper evo induction kit (with cold air feed) & a ported & polished head.
just trying to find out all the pro's & con's of the catch tanks.
thanks for that anyhow.
e30den
Post Sun Feb 28, 2010 5:56 pm
Your motor sounds sorted.
i put a search into google and found www.enyperformance.com
there is an article on oil catch tanks and there function
HTH.
steve_k
Post Sun Feb 28, 2010 10:28 pm
e30den wrote:Your motor sounds sorted.
HTH.
thanks for that i'll have a look.
MillRat
Post Mon Mar 01, 2010 12:01 am
I run an oil catch can on my M20. It has stopped a lot of oil returning to the throttle body, phlenum and motor, however I could not tell you whether it has made any power difference or not.
Cheers,
Michael.
