oil light on when car is stood still
pepperami
Sun Feb 21, 2010 7:02 pm
bmw 325i touring auto when its warm the oil light flashers when in gear bit of a cold ass on moning any advice
stonesie
Sun Feb 21, 2010 7:06 pm
So when the engine has warmed up your oil pressure light flickers when the car is idling in drive?
How about in neutral?
Have you checked the oil level?
Can't help with your backside though 8O
BillyW
Sun Feb 21, 2010 7:08 pm
check if the oil levels ok or could be a worn oil pump?
Sun Feb 21, 2010 7:22 pm
pepperami wrote:when in gear bit of a cold ass on moning any advice
Write in something vaguely resembling English, and you may get helpful replies!
Also, check the bottom row of your keyboard for useful things like commas, full stops and a shift key.
psychochild187
Sun Feb 21, 2010 7:42 pm
lol
Morat
Sun Feb 21, 2010 7:46 pm
Which oil light is it?
stonesie
Sun Feb 21, 2010 7:47 pm
I was guessing the pressure light, the level light just comes on and stays on if it's working.
e301988325i
Sun Feb 21, 2010 9:00 pm
Make sure you have a genuine BMW oil filter fitted and you're not using some cheap crap to save £5. Cheap filters can be restrictive and will starve your engine of oil pressure and kill it eventually!
I said:
e30topless said:
lock the wife in there
Ranchero
Sun Feb 21, 2010 9:14 pm
Seriously? I've just put a non-BMW filter on my car. Please tell me you're overstating the case.
Baz666
Sun Feb 21, 2010 9:22 pm
I also have the same thing at the mo, when my car is cold its not on but when it get to tempture the oil can light which is the oil pressure ? starts to flicker on and off but if i rev the car either in idle or driving in gear it stays off......i`m guesing its the oil pump as i`v changed the switch and this weekend its had a oil and filter change. :cry:
stonesie
Sun Feb 21, 2010 9:28 pm
The Oil light on the dash is for the pressure, If it lights it is possibly the pump that's worn or it could have worked a little loose, to find out is a sad and messy job of removing the sump on the M20.
Baz666
Sun Feb 21, 2010 9:40 pm
is that an engine out job for that ???
Sun Feb 21, 2010 10:29 pm
BMW state that it's acceptable for the oil light to just flicker on at idle on a hot engine.
(That's BMW's opinion, not mine!)
Sun Feb 21, 2010 10:31 pm
Baz666 wrote:is that an engine out job for that ???
the sump can be removed in situ, but it's a sad job ..
personally i would take out the engine and change all the gaskets ect while it's out ...
Baz666
Sun Feb 21, 2010 11:04 pm
Thanks Brain
if the engine as to come out then thats fine as i want my engine total cleaned and the bay repainted anyway.
e301988325i
Mon Feb 22, 2010 7:15 pm
Ranchero wrote:Seriously? I've just put a non-BMW filter on my car. Please tell me you're overstating the case.
I was told to only use BMW filters by someone I respect who has nothing to gain from me using them. BMW M20 oil filter is 10 or 11 quid. . . might just be folklore. Perhaps Brian could add his knowledge
Ps) A warmed up M20's idle oil pressure is just over 10psi.
I said:
Baz666
Mon Feb 22, 2010 7:24 pm
anything oem is going to be better for your car fella.
