Now the MS project is nearing the installation stage, I am looking for a place close(ish) to L'boro/Leicester with a rolling road and full emissions equipment to collect some data on my car before the ECU and sensors etc. go on the car
I will probably be doing mostly steady-state tests at a number of speed/load points and measuring emissions (CO,CO2, NOx, HC) and an approximate fuel consumption (got some old flow meters installed) and then doing a power run.
A few months later after the install and on-road tuning I will need to return to tune the high speed/load tables and take the same set of measurements.
So, does anyone know a good place to go?
