locked out
jordano
Post Fri Aug 26, 2005 7:45 pm
Help anyone anyone know how to open the doors in central locking mode had the battery off to charge when i put it back on alarm locked both doors and boot keys in the ignition alarm fob hanging off the keyring its a cab so i think i can maybe prise the window open a bit but wats the best thig to use to lift the button up it will be tight cause the plunger will be set down any ideas would be most welcome
Widge
Post Fri Aug 26, 2005 7:52 pm
When my fuck wit of a mate locked my keys in my old Golf the AA man used a bit of plastic pacel wrapping tape, you know the tight strong stuff they use to wrwp boxes and stacks of magazines in factorys. But I think you will have a problem with the cab as the lock toggles are flush. Try pulling the interior door handle.
Artis
Post Fri Aug 26, 2005 7:55 pm
call the aa they will open it in about ohhhhhhhhh 30 seconds :mad:
Handy
Post Fri Aug 26, 2005 8:13 pm
Dead easy....Slash the roof 8O
Just kiddin'
The window should slide down if you are careful and patient.
Widge
Post Fri Aug 26, 2005 8:20 pm
If you can get somthing in the window push the catches to open the front of the roof!
orkboss
Post Sat Aug 27, 2005 9:23 pm
Have you tried undoing the live battery terminal and just touching the live terminal with the lead. This surge can cause the central locking to open.
jordano
Post Sun Aug 28, 2005 12:09 am
sorted now thanks everyone for your help i used a tape measure folded in half then pulled it tight round the door pin and up it popped
Widge
Post Sun Aug 28, 2005 10:23 am
I thought all cabs had flush door pins??
Oh well I suppose not!
