horrible clunking sound from rear...
Staff
Post Thu Feb 11, 2010 2:50 am
On collecting my e30 today ive found the car clunks when changing gear or pulling out of junctions or reversing. the car has had new dampers fitted for the MOT last august. also the gearing sounds dry and makes a whining sound. Could these be linked? Im thinking either low gear fluid level. low diff oil level. knackered box or diff and perhaps knackered rear beam bushes or rear strut top mounts. any diagnosis would be greatly appreiciated. also if anyone has a how to guide in relation to fitting the rear beam bushes that would be ideal. car is on 146k has full history. please help as its my daily driver and i commute 40miles a day. :D
m_jermyn
Post Thu Feb 11, 2010 10:13 am
Top mounts
Post Thu Feb 11, 2010 10:15 am
m_jermyn wrote:Top mounts
+1.
sihooker
Post Thu Feb 11, 2010 10:17 am
...and get the gearbox and diff oil changed ASAP!
ChemicalAl
Post Thu Feb 11, 2010 3:53 pm
Rear subframe bushes sound like the culprit - These require a special tool to get out (or a lot of pain, anguish, utter frustration and bloody fingers). IMHO tis best to buy the original bushes from BMW and get a BMW specialist to replace (mine cost £120 all in to get them done).
1987 E28 528i Diamond Black 74k
1986 E28 525e Saturn Blau 72k
1988 E28 525i 56k
1987 E28 525e 51k
1991 E32 730i SE Granite Silber 75k
1988 E30 316 Black 81k
1992 E30 318i Touring Diamond Black 43k
1990 E30 325i Touring Alpine White 2 65k
1986 E30
mrLEE30
Post Thu Feb 11, 2010 4:31 pm
i disagree with all above!!!
this sounds like the diff bushing or the diff itself. the clunk could also be due to centre bearing. both are easy to check and replace.
top mounts make noise over bumps, and rear beam bushed rarely fail to the point of noise when pulling away.
the whining could be anything from gearbox to diff.
you can see the diff bushing below on the top Left side
Post Thu Feb 11, 2010 5:36 pm
my rear subframe bushes were well shagged, it made plenty of clunks :eek:
spacechimp
Post Thu Feb 11, 2010 5:57 pm
I'd have to disagree that the diff bush will make it clunk, mine was hanging off coz the cast ally diff mounting had cracked and it did'nt clunk, it scraped abit tho. also before i had this little set back i failed my mot due to knackerd diff mounting bush and it did'nt clunk. i'd check your diff oil thats easy to do, and your gear box, i suspect your problem lies here. i have a spare diff off a 318, the mounting is cracked but you could swap that off your old one if thats the problem. bushes tend to clunk when you go over dogy road or speed bumps. if you've got the money and you gonna be commuting you should put poly bushes in ,they stiffen up your ride a bit but not to much .they last longer tho. when ever i've had a bush go i've replaced it with a poly.
ucpsale
Post Thu Feb 11, 2010 8:33 pm
Centre prop bearing makes a nice clunk when that has failed.
Post Thu Feb 11, 2010 8:36 pm
spacechimp wrote: if you've got the money and you gonna be commuting you should put poly bushes in ,they stiffen up your ride a bit but not to much .they last longer tho. when ever i've had a bush go i've replaced it with a poly.
If your going down that route, I would upgrade your Top rear mounts to E46 cabby ones, trust me you'll need them.
sihooker
Post Thu Feb 11, 2010 8:59 pm
If you're using the car for commuting, I would say the last thing you would want is polybushes! Get decent OEM-quality rubber bushes and they'll outlast the car...and wont remove the fillings from your teeth in the process. Most BMW bushes have done 15+ years before they needed replacing, and some, like mine, have done 20 years and still pass the MOT!
Staff
Post Fri Feb 12, 2010 4:23 am
Thanks for the posts people. Got the car on the four poster in a friends garage and as i guessed. the rear beam bushes were absolutely cream crackered to the point where u could jack up the rear beam and it just moved up and down the bush. also the O/S rear top mount was starting to separate. Im goin to repair it myself. i will make a tool to withdraw the bushes then reverse the procedure to fit them. also the cars last inspection 2 service was in 2006 so four years of use the oil is probably way outa spec. will post pics and possibly do a how to guide...
