Seams a shame to scrap the bits so i though i'd see if theyre any good to anyone on here.
All parts were from a suspected HG failure but it seamed fine when i stripped it all.
ive got
Con rods and Pistons
Both throttle bodies (think ones got something to do with cruise control)
Lower Sump
Upper Sump
Dip stick
Oil Pump
Crank
Front Lower Timing Case
Upper Timing Cases (off each head)
Oil filter housing
Engine mounts (think ive got both)
2x Complete heads
Flywheel
PAS pump
Crank pully
NO inlet tract parts or manifolds soz
