Differences
Banjo1981
Post Tue Jan 26, 2010 9:05 pm
Not sure this would technically (get it?) be the right place for this but...
Is there a difference between
Facelift-Chromie front wings?
Is there a difference between 2 door/ 4 door wings?
Is there a difference between the injectors for a 1.8-1.6 M40 engines
TIA
Ant
Banjo1981
Post Tue Jan 26, 2010 9:27 pm
Thank you sir. You're a scholar and a gent.
H35-24
Post Tue Jan 26, 2010 9:29 pm
Well, why don't you go nuts with the parts numbers on either bmwfans.info or www.realoem.com.
On bmwfans if say you look up the injector on the 1,6 M40, click the partnumber and you get a list of models were this injector is used.
On Realoem you have to copy the partnumber and paste it into the partsearch box on the front page. By default it only lists US spec cars, so you have to choose euro spec before you do the search otherwise you'll have to repeat it.
Why is there not enough time to do it right, but allways enough time to fix the errors - I borrowed that, just so reallistic in my line of work.
