m20 SWAP EARLY DIZZY CAP LOOM TIPS
GT-UK
Sun Jan 24, 2010 8:11 pm
EVENING
any tips on loom work when changing an early m20 2litre to a later non dizzy engine,
obviously there will be some little wiring issues, any help on this would be great
thansk in advance people
changes on a weekley basis
Sun Jan 24, 2010 9:18 pm
You need to use the engine loom that goes with the version of Motronic you are intending to use.
Does the car have the old square type engine loom socket (by the fusebox), or does it have the later 20 pin round one?
GT-UK
Sun Jan 24, 2010 9:21 pm
evening
cant check at thsi moment but ..
im going to presume its a later unit as its a 1986 2.0 car ?
with a 1990 2.5 going into it
Sun Jan 24, 2010 9:25 pm
If it's the later unit, the loom will plug straight in, BUT see my stickied 'engine swaps warning' in the engine swaps forum.
GT-UK
Sun Jan 24, 2010 9:31 pm
plug straight in even with the dizzy cap being run thru the old loom,
(just checking yr stickie)
Sun Jan 24, 2010 9:34 pm
I think you're going to find your car has the older type socket, although I'm no expert on this older stuff.
GT-UK
Sun Jan 24, 2010 9:39 pm
the wiring will be the only stumbling block, ok to PM you if i need a tip or 2 ?
cheers
chris
Sun Jan 24, 2010 9:49 pm
Would be better to stick it on here! There are others (willnz, where are you) who know more about the old type connector than I do.
GT-UK
Sun Jan 24, 2010 9:58 pm
cheers i for your help
