E30 friendly MOT station
demonbiker
Post Tue Aug 23, 2005 10:25 pm
Need a E30 friendly MOT centre in Herts/Essex/North London
Any ideas??
'90 M5 3.6 "Driven Hard......Put Away Wet!! "
Bharat
Post Tue Aug 23, 2005 11:36 pm
Don't know about E30 friendly, but my local place are honest, good lot.
What's your need ?
325i Motorsport Edition convertible - gone, but not forgotten.
Ant
Retired Team Member
Retired Team Member
Post Wed Aug 24, 2005 12:07 am
he needs them to not rollertest the rear brakes as it could damage the LSD , its in the testing guidelines BTW :wink:
the MOT standards are low in comparison to other countries, tested by the book, most vehicles should pass, the key words are " acceptable" the problem there is by whoose standards ?
the beauty, as always is in the eye of the beholder gents 8)
Jon_Bmw
Dangerous when thinking
Post Wed Aug 24, 2005 11:30 am
Can you got ask the garage not to use the rollling brake machine, they should have a braking force meter that they drive the car along, slam on the brakes and if its in the set perameters then it will pass. The parameters are also fairly helpful :D
I know this as you can't test 4x4 vehicles unless they have a 4 wheel drive ramp or a way of disconecting the 4x4. Go and voice your concerns with them, they may just say we won't bother with the rear wheels, depends how well you know your MOT garage i suppose.
Hope this helps a bit
Jon
jumare
Post Wed Aug 24, 2005 5:10 pm
I've just had my 325 Sport tested, see other thread it failed :-(
I pointed out about the LSD and he still used rollers, said it was OK, and this is a former BMW mechanic. It is a new test centre perhaps it depends on the type of rollers?
Hope nothing's broken, although at the moment that would be the least of my troubles.
Mark
