No idea m8. You may remember i'm useless with stuff like this.
You lost me at the "Unichip" bit ..
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
'89 E30 325i
Anyway ... someone with half a brain cell will be along shortly to answer this.
'89 E30 325i
Apparently i'm not the only stupid one round here.
'89 E30 325i
You can bu the replicator and the base but they can not be coppied unless you can break 256bit encryption which would cost more than programming your own map for the conversion.
See here, http://www.evc.de/en/
No I cant copy this chip. I can however copy the main eprom but it is mapped with the pectal pcb so its pretty useless.
Sal are you sure this chip can be used then for a one off custom map with MAF. If thats the case I may as well use it.
I dont see me doing anything else to engine has most stuff is sorted.
