gearbox mount/bushes
chrisroberts
Post Sun Jan 17, 2010 10:05 pm
Can you get harder bushes than the standard rubber ones for the gearbox mount? I dont want solid bushes as with the engine being mounted using bushes it would transfer alot of stress onto the solid bush/mount??
leeparkes
Post Tue Jan 19, 2010 12:13 am
Ive read that E21 mounts are stiffer than E30 ones, something to do with the E21 only using one mount in the middle, (hence being stiffer) but they are the same size as the E30 ones so fitment isnt an issue.
e301988325i
Post Tue Jan 19, 2010 9:04 am
Hmm that's worth knowing
I said:
e30topless said:
lock the wife in there
chrisroberts
Post Tue Jan 19, 2010 10:05 pm
leeparkes wrote:Ive read that E21 mounts are stiffer than E30 ones, something to do with the E21 only using one mount in the middle, (hence being stiffer) but they are the same size as the E30 ones so fitment isnt an issue.
Cheers for that! I'll have a look into it!
e301988325i
Post Sun Mar 28, 2010 6:41 pm
E30 is M8, E21 M10. trying got find out if they actually fit or not.
I said:
MillRat
Post Sun Mar 28, 2010 11:23 pm
AKG make a vast range of components for E30's including different compound bushes.
http://www.akgmotorsport.com/catalog/ca ... s%20Mounts
Cheers,
Michael.
Post Mon Mar 29, 2010 12:04 am
E21 mount Vs E30 mount
I use these on my 24v cars, you can also buy machined aluminium cups that fit over the bush and reduce movement even more
djs325
Post Sat Apr 10, 2010 6:54 am
You can order the Ireland Engineering Items from BimmerWorld; I have installed these on a couple of cars with good reports. The AKG ones are a bit too hard; they can snap off the mounting tabs of the back of the Getrag gearbox!
Whiteline also do a gearbox mount kit (W92839), which I will investigate for my next car...
E30racing.com.au - Like Production BMW Cup, but upside down!
