fit rad off e28 or 34 donar
prop? change the gearbox flange?
loom change two wires around (its a 2.5 motronic job)
engine mounts where can i get these?
any pointers will be much appreciated, may even start a build thread
CorrectedSpeedtouch wrote:leeparkes on here sells the engine mounts. Here's his ad:
http://www.e30zone.net/modules.php?name ... c&t=155113
Yes but e34 donor rad has to be non air con (air con rads are massive and wont fit between the chassis rails) i used an M20 rad for a while with no issuesbmwnut88 wrote:
No flange twisting for me but it is close.zaust wrote:You will also need to turn the flange on the exhaust manifold (nearest the steering coupling) 90º or it will fowl the linkage.
I only had to do this when I fitted an E46 330sport rackleeparkes wrote:No flange twisting for me but it is close.zaust wrote:You will also need to turn the flange on the exhaust manifold (nearest the steering coupling) 90º or it will fowl the linkage.
324td propshaft is also perfect fitcharlE30 wrote:If you can find an M3 E30 prop it's perfect bolts the M30 box straight up with the E30 diff![]()
I like Lee used an E30 325 rad for a while, kept the temp almost exactly the same as my E34 replacement.
324td as in an E30? Or a 325td E36 and a typo?vokietis wrote: 324td propshaft is also perfect fit
PazzaAE86 wrote:324td as in an E30? Or a 325td E36 and a typo?vokietis wrote: 324td propshaft is also perfect fit
