hi,
i have been offered a m30 with gearbox for a reasonalbe price, but the problem is there is no loom or ECU.
would this be a problem? i know that the m20 loom can be used but i would rather get a m30 one, are the ECU and loom easy to find/buy?
M30 without ECU and loom
PazzaAE86
There is a few ECU's on ebay and alot of E34's being broken. Should be ok?
Theo
A manual gearbox is probably the hardest thing to source, I wouldn't worry about lack of loom/ECU - although I guess this means you can't hear it running?
Are the engine & gearbox from an E34 or E28?
leeparkes
Try on here in the wanted section for a loom or on here
http://forum.bmw5.co.uk/viewforum.php?f=17
M20 can be used, see here http://www.e30zone.net/modules.php?name ... c&t=156582
ECU, M30 ones are easy to come by but you can also use an M20 ecu with the chip swaped, im sure Rav is using an M20/b20 ECU with one of speedtouch's chips
As said id buy it if it was cheap for the manual gearbox alone.
- E30 Zone Meets/Events Team
Sure am, using a M20 325 ecu with Speedtouches chip and works fine.leeparkes wrote:Try on here in the wanted section for a loom or on here
ECU, M30 ones are easy to come by but you can also use an M20 ecu with the chip swaped, im sure Rav is using an M20/b20 ECU with one of speedtouch's chips.
PazzaAE86
Pleased to report the M20 loom works fine, the loom i bought was damaged hence the car not running. Sorted now, fired up about 10 minutes ago and sounds pretty sweet, more like a WWII aeroplane than a car!
I take it you fired it up without the Exhaust manifold on then???
PazzaAE86
Well, manifold was on but no downpipes etc! But yeah didnt wanna waste time fitting exhausts and filling with coolent etc if the engine was toast already....
charlE30
It's a well know rule that when doing an M30 conversion you have to start it up wthout an exhaust system fittedPazzaAE86 wrote:Well, manifold was on but no downpipes etc! But yeah didnt wanna waste time fitting exhausts and filling with coolent etc if the engine was toast already....
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
