s50 exhaust diameter
what part of the system?
Do you mean the primary tubes or after the collectors where the flexi pipe is?
I would recommend against a single pipe system as the S50 engines are very sensitive to how well the exhaust gases exit, any meddling with the system can have massive effects on the performance.
Standard systems have the 6 branch, then into a x pipe and then into a twin pipe system.
I cannot recall what diameter the pipes are on the system, but i would guess they are at least 2.5"
