I'll post this in the header as its a keeper
http://rickk.net/i/drive/bmw-e30-325i-m ... formation/
BMW E30: 325i Motronic 1.0 Information
After I installed a rebuilt 325i engine in my (previously L-Jetronic) 320i I had a lot of ”afun”a getting it to idle correctly.
It idled, but not very well and I had occasional troubles with stalling or hard starting every time I fixed some component of the system.
In the end, I got so tired of it I just decided to check EVERYTHING and get everything back to factory spec. Unfortunately, the early Euro 325is (without catalyst) used Motronic 1.0, which is not documented very well, in workshop manuals or on the web.
Most information is on Motronic 1.3 as used in the later E30s with catalyst, and while there are many similarities, there are a few differences, for instance:
* Motronic 1.0 doesn’t have an O2 sensor / lambda control
* Motronic 1.0 uses a 2-row 35-pin connector on the ECU instead of the three-row 55 pin one.
* Motronic 1.0 has an additional idle air bypass screw on the throttle body
There’s also quite some information on the early US 325(e)s, which is in general more comparable, but again there are differences:
* No separate idle control module (ICM), function integrated in the ECU.
* No cold-start injector
* No thermo-time switch
As long as you’re aware of these differences, many of the information on both these systems is fully applicable (including sensor resistance values, voltages, etc.), but you have to be a little creative.
To help you a little on this I’ve written this document which is specifically geared to Euro Motronic 1.0, but ofcourse might just as (non-)applicable to other Motronic versions. YMMV.
Theory of operation
ECU Connector Pin-Out
Pin Pin
1 Ignition coil output 19 Ground
2 Idle switch 20 Main relay
3 WOT switch 21 Tachometer
4 Cranking signal 22 AFM Temp sensor
5 Ground/Crank PosS Gnd 23 -Inlet Air Temp/Crank SpS Gnd.
6 AFM ground 24 O2 sensor signal *
7 AFM signal 25 Crank position sensor 1
8 Crank speed sensor 1 26 Crank position sensor 2
9 AFM supply 27 Crank speed sensor 2
10 Auto only special 28 Water Pressure switch
11 Fuel consumption gauge 29 A/C switch (if installed)
12 30 +Inlet Air Temp
13 Water Temp 31
14 Injector output cyl 3&4 32 -
15 Injector output cyl 1&2 33 ICV pulse
16 Ground 34 ICV pulse
17 Ground 35 Injector ground
18 -
Checking the Motronic components
Connectors and wiring
As the whole wiring loom in most of our cars is now over 15 years old, wires and connectors tend to be pretty oxidized by now.When you check any of the following components, inspect and clean (with electric contact cleaner and a toothbrush) their connectors carefully.
One connector that you won’t find by following the guide below is the large round connector mounted on the firewall, next to the fusebox. This connector mates the various wiring looms in the car together and can corrode pretty badly over time, causing all kinds of intermittent and unexplainable failures. You can easily unclip it from the firewall and it screws open by turning the two halves a quarter clockwise.
Coolant Temperature Sensor
Motronic uses the Coolant Temperature Sensor to determine if the engine is cold or at operating temperature and adjusts the fuel supply accordingly. If it fails, it usually thinks the engine is cold, causing a rich mixture all the time.
The temp sensor is a blue sensor in the thermostat on top of the front of the engine. Don’t confuse it with the brown sensor which is only used for the gauge in the dashboard.
The resistance between the two pins should read:
* around 3KOhm when cold
* around 200 Ohm when hot
If it’s faulty, it needs to be replaced which implies you’ll need to drain some coolant. As a kludge you could connect both terminals with a 200 Ohm resistor so it’ll at least idle correctly when hot.
Idle Control Valve (ICV)
The ICV is used to allow extra air to bypass the throttle when the engine is cold.The ICV is the black tube thing on top of the engine, sticking in the large rubber intake boot and the throttle body.
First check if the valve is still ”˜electrically’ okay by unplugging the connector and measuring resistance with a multimeter:
* resistance between outer terminals: around 40 Ohm
* resistance between each outer and the inner terminal: around 20 Ohm
If anything is wrong with these values, one or both of the coils is burnt and you’ll need a new one. Price is about 130 Euros at the stealer. As an additional test you could apply 9V to the inner pin and - to one of the outer pins, the valve should open or close with a audible ’snap’.
If the valve seems to be okay, turn on the ignition measure the current from the ECU to the valve at the connector:
* between the inner pin and ground there should be battery voltage
* between any outer pin and the inner pin there should be around 10V
If these values are off, something is wrong with the ECU, or something is wrong with a signal to the ECU. The signal to the outer pins comes from ECU pins 33 and 34, the inner pin is fed from somewhere else (sorry, haven’t trace this wire).
Now, take the valve off the car and see if it moves freely by quickly rotating the housing. If it doesn’t (or just looks icky), clean it out toroughly with carb and/or electric contact cleaner. Using WD-40 over here is said to attract to much dirt over time, but trust your own instincts on this.
Throttle Position Switch (TPS)
The TPS is mounted on the underside of the Throttle Body (TB) and tells the computer if the throttle is closed, partially open, or wide open (WOT). As the switch is mounted on the bottom of the TB, oil, fuel and other crud tends to find it’s way into it, causing it to fail eventually. When it fails, it results in erratic idle, higher fuel consumption or lack of power on WOT.First check if you hear an audible click when you fully close or open the throttle. If you don’t hear this, the switch is really shot, misaligned or somebody messed with the throttle stop.
If you hear it clicking, check if it actually works by disconnecting it’s connector and measuring continuity across it’s pins.
* With the throttle closed there should be continuity between the inner and one of the outer pins
* With the throttle partially open there should be no continuity between any of the pins
* With the throttle fully open (about 7 degrees from it’s end) there should be continuity between the inner and the other of the outer pins
As a quick check if at least the idle switch is working you could disconnect the connector with the car idling. The idle speed should rise when you do this.
Air Flow Meter (AFM)
The AFM meters -unsurprisingly- the amount of incoming air. Basically it’s just a spring-loaded flap in the intake connected to a potentiometer. As the engine sucks in more air, the flap gets pushed open wider and so the resistance of the potentiometer changes. By measuring this resistance, the ECU knows how much air is entering the engine, and thus how much fuel is needed.There’s a number of things that can go wrong with the AFM:
* The idle mixture bypass screw can be out of adjustment, causing a wrong idle mixture.
* The spring tension for the flap can be out of whack, causing a wrong idle and part-open throttle mixture.
* The flap can stick due to carbon buildup or because it’s out of alignment (because of a backfire for example), causing all kinds of freaky stuff.
* The carbon track can wear out, causing all kinds of freaky stuff, usually cutting out.
Fuel Injectors
While they can get quite noisy (according to some people, you should only be worried when they stop making noise), the fuel injectors on these cars rarely break, but you can check them to be sure.They can get clogged up though. You could try running some injection cleaner trough the fuel (doing this once in a while, just before an oil change might be good preventive maintenance anyway), or try a ”ahot soak”a procedure (do a google search), but if they’re really clogged, it’s probably best to remove them from the car and bring them to a specialized shop (in Europe, the Bosch Car Service Centres do this and are present in most areas, cost about 12 Euro per injector). As a bonus, they’ll replace the O-rings, the tiny filter in the injector and measure the spray pattern and flow rate. I had them cleaned on my car and noticed a slight different in the idle, but a definate difference in power in 4th and 5th gear.
Adjusting the base idle speed and mixture
First, make sure everything else is up to spec (check sensors, ignition, air leaks, throttle, TPS, etc.) before messing with these settings. The factory settings should be pretty much spot on, perhaps a little lean if everything is working fine.If that’s okay, warm the car completely, and unplug the TPS connector and short all three pins together. This instructs the ECU not to ”amess”a with the idle speed and sets the the ICV in a nominal position.
Start the engine and adjust the idle with the bypass screw on top of the TB. Try to set it to around 800rpm. Rev it in-between adjustments, as sometimes the adjustments don’t have an immediate effect. If you can’t get the idle up high enough, your mixture is too lean, so you need to dial in some with the bypass screw on the AFM.
Adjust the mixture in small steps (wait about 30seconds each half turn for the computer to ”˜catch up’) to obtain the so-called ”abest high idle”a, which means that you stop enrichening the mixture as soon as the RPMs stop rising when you do so. Now, lean it out 1/4th of a turn again, this should provide an ”aabout right”a mixture. Next, rev it up to about 3000rpm and quickly close the throttle. If the RPMs drop briefly under the set idle RPM and then come back up the mixture is too rich and you need to lean it out a little more.
If you can’t turn the screw anymore (usually inwards/richer) and still haven’t reached a correct mixture, the AFM spring probably needs adjustment. Turn the screw to approximately half way, open the AFM and adjust the spring one or two notches either way (clockwise is leaner, ccw is richer, exactly the opposite of the CO screw), until it runs better, then make final adjustments with the screw.
If you think you’ve got it right, plug back in the TPS and take it for a spin, and make minute adjustments to your likings.
It’s probably wise to check with an exhaust gas analyzer (drive by your garage or a service shop) afterwards if the CO is within spec (0.5-1.5), but following the above you should be able to set the idle pretty much to spec without.
If you can’t get it to idle correctly this way, you have another problem. Most likely your valve clearances are set too tight.
325 Idle: Blog on Tuning Motronic
bpowell555
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby
bpowell555
From this it sounds like mine might be running rich - but I don't get how he's adjusting the idle and how the mixture? Are there two screws?
... or are they the same thing and turning it "out" is leaner?
1990 325i touring
bpowell555
Ok, idle adjust screw on the TB, mixture adjust screw on the AFM (in is richer). If I think its running slightly rich then I should be able to turn the AFM screw a touch out, right?
This is also good:: http://www.dtmpower.net/forum/e30-3-ser ... -rich.html
1990 325i touring
Bob_S
Running lean is bad for you, well I heard Will say he isn't keen on the idea but if needs mustwillnz wrote:Right, but mark where it was before so you can return to that if necessary. You should back up your adjustments with a CO meter asap. you dont want to be running lean.bpowell555 wrote:Ok, idle adjust screw on the TB, mixture adjust screw on the AFM (in is richer). If I think its running slightly rich then I should be able to turn the AFM screw a touch out, right?
Bollocks to this 24v scrap!
Maybe its not documented as well as it could be, There are many late motronics with the 3 row ecu that dont actually have an o2 sensor, the provision for the sensor is there, the wire is normally clipped up under the battery tray but almost always has a blanking plug on it. only late J and L plates actually had an o2 sensor so dont go changing your engine loom for that, you'll just be downgrading.
Kieran_n22
thank you! I love you for this! lol
now this seems like the perfect place to ask a question! i have just bought a 1987 325i tech 1, my first e30
the only issue i have is that it idles quite high, at around 1200 rpm, and sometimes this can rise to 2000 although a blip of throttle brings it back to 1200.
it is running the mototronic 1.0 system. i have replaced a faulty throttle position sensor and this is now working correctly, and i have been through everything mentioned in this thread (which is great by the way). the only problem i have found is that at the ICV i am getting 12v between the centre pin and earth, 10v between one outer pin and centre, but 12 between the other outer pin and centre.
Does anybody know what feeds these pins? or has anyone had this problem before. I am mechanical but i have never dealt with an e30 before, so any advice is welcome
