Triple weber conversion on m20 engine
raasayphil
Post Sun Nov 29, 2009 4:56 pm
Hi
I am looking for any guidance on converting to triple webers and in particular concerning removal of the ECU and sensors and how the timing etc is controlled
BadDave
Post Sun Nov 29, 2009 8:57 pm
Try contacting e21jason for info, as he has a set on his 2.7L track car.
He should be in a position to advise accordingly.
HTH
Turbo-Brown
Boost Junkie
Post Sun Nov 29, 2009 10:16 pm
Don't do it! :)
Or if you do, at least invest in a mappable 3D ignition system!
dcoeinside
Post Mon Feb 08, 2010 7:12 pm
Turbo-Brown wrote:Don't do it! :)
That´s of course the best way. But the engine is also running with a stock modified ignition system from an early M20B20.
[youtube][/youtube]
Regards
Christoph
Post Mon Feb 08, 2010 8:11 pm
Wow thats awesome. Sounds great. Is that your E30?
Turbo-Brown
Boost Junkie
Post Tue Feb 09, 2010 7:38 am
That does sound lovely, although ITBs and electronic ignition can do everything that carbs and clockwork dizzies can only faaaaaaar better.......with the possible exception of acceleration fueling for snap throttle openings.
dirtydog100
Post Fri Feb 12, 2010 8:15 pm
where do you get the manifold from to fit?
what cabrs, 40s 45s?
jets?
managment?
that beemer sounds amazing, and they look stunning!
bradderse30
Post Sun Apr 11, 2010 5:38 pm
i wanna no aswell im intrested in doing it :mad:
MillRat
Post Thu Aug 05, 2010 8:38 am
Old thread I know, however I got my M20 weber manifold from Rowland Manifolds in South Africa.
The only modification I had to make was to enlarge one of the recesses for the manifold nuts and cut out the metal between each throat as I run Solex carbies (they have an adjustment screw between each butterfly, which fouled as the throttle was opened). Both modifications were easy. I got mine about 2 years ago for AUD350 landed, which is a great price if you ask me.
I must add though, that I stuck these on an E21, which doesn't have the firewall mounted brake booster.
http://www.manifolds.co.za/?page_id=21
Cheers,
Michael.
dirtydog100
Post Fri Sep 24, 2010 10:10 pm
cool, im still fiddling around with mine, il have pics up soon i hope
timmy1701
Post Fri Nov 26, 2010 4:33 pm
I love the idea of putting carbs on m20s, might even do it myself some day...
Anyone know who this is and whats been done to the engine? 209 whp...
http://www.racecarsdirect.com/listing/3 ... k_car.html
