rack conversion..
CHR1S1990
Post Thu Nov 26, 2009 4:24 pm
Hi guys
was reading an old but good thread on fitting the z3 rack on an e30...they seem pretty hard to find and i dont live near any scrappies (to my knowledge). how different is it to fit an e36 rack? and which rack has the closest ratio to the z3? does it require any modifications to fit? i dont have a 6branch manifold, yet, so thats no worries
any help would be great
cheers
chris
e301988325i
Post Thu Nov 26, 2009 5:29 pm
E46 330i SPORT rack required + PAS oil cooler. the E30 steering coupling fits the E46 spline too.
3.0 turns, same ratio as Z3 but more lock and better weighting.
part numbers below from my rack, I beleive the middle line is the part number.
7852 974 679
6 755 067
006888 0701
Ps) You must get a SPORT rack else the steering will be 1 finger light. normal racks are only 1 number different.
I said:
e30topless said:
lock the wife in there
CHR1S1990
Post Thu Nov 26, 2009 5:49 pm
PMd mate
e301988325i
Post Thu Nov 26, 2009 5:59 pm
Buy it. You will need an oil cooler though. i used an E46 320d one, and put it behind the kidney grills. I paid £60 inc delivery for mine. I've just sorted 'MONKEY' on here out with one of these, he's very happy.
I said:
CHR1S1990
Post Thu Nov 26, 2009 6:18 pm
is it imperative to get a cooler on? just need to sort out courier for the rack..
is the rack a near direct fit or will i need to source any other parts?
thanks
CHR1S1990
Post Thu Nov 26, 2009 6:28 pm
is it the cooling coil i need? found this..
http://cgi.ebay.co.uk/E46-320-ETC-POWER ... 4149cbc093
CHR1S1990
Post Thu Nov 26, 2009 6:38 pm
just checked realOEM and the part numbers for the 330Ci seem to match...am i in luck? 30quid seems a bargain
cheers
charlE30
Post Thu Nov 26, 2009 6:53 pm
Out of interest why is the cooler needed on the 330 sport rack? I've got mine fitted without, will this potentially damage the rack in some way???
The rack is a direct fit, mine is in the forward mounting holes on the subframe and the E30 steering coupling bolts straight up.
BMW F31 335d xdrive
e301988325i
Post Thu Nov 26, 2009 7:04 pm
That is the cooler I'm using, I paid £15 but really any cooler will do that will fit conveniently, I've got some pics on here of it, I'll find them. The rack rits in the front mounting holes, I've got a 7.5mm spacer above and below the rack.
The rack has some form of pressure reduction valve to give the nice weighting, this puts extra load on the pump and heats the PAS fluid to boiling point. . . steering nearly jams solid, not fun around the ring. Monkey had the same problem.
I said:
monkey
Post Thu Nov 26, 2009 7:08 pm
mine was heating up the fluid and pushing it out the top of the bottle . it doesn't do it now with the cooling pipes fitted . i used a cooler from a scrap rover 214 it was the only bit that wasn't rusty on it :)
e301988325i
Post Thu Nov 26, 2009 7:15 pm
I zip tied the 180 degree bend to the plastic shroud (in front of the radiator, behind the kidney grills) which I drilled two 5mm holes through for the zip tie. I had to remove the grill.
lower pipe is from the return of the rack, top pipe returns to the reservoir, self bleeds this way.
You must use oil grade hose, it's not expensive. Car water hose will be eaten by PAS fluid.
Hi Matt, we've got another convert here! I think this is going to be the rack of choice from now on. I wonder how many are out there.
I said:
CHR1S1990
Post Thu Nov 26, 2009 9:05 pm
thanks for your help e301988325i, will sort rack courier out and have just bought the cooler
e301988325i
Post Thu Nov 26, 2009 9:20 pm
No worries, I owed you for your help with my lpg!!! Is that your car in the sig? Looks nice, blue or black? 325? Cheers Alex
I said:
CHR1S1990
Post Thu Nov 26, 2009 9:28 pm
well, you scratch mine..:D yeah it is met black, 2.0l at the moment..sadly! just preparing my car for a 2.8 (m20 single cam rightness) so thought i would start with the rack, bought rear disk set up the other day, LSD will be next! hows the LPG? getting about 25mpg atm, loving it!
e301988325i
Post Thu Nov 26, 2009 9:32 pm
I've seen your courier question, I believe you don't require the track rods, you use the E30 ones, check elsewhere first though, mine's been on a while I've forgotton. You do want the E46 steering rack boots IIRC. You also won't need the steering column coupling attached to it.
Or get them to remove the track rods and packaage it all together side by side.
Then it's not a very long at all.
I said:
e301988325i
Post Thu Nov 26, 2009 9:41 pm
Nice, 2.8 m20 is on my list, a long way down but there none the less, tuning the original engine is just the right thing to do.
Loving LPG, apart from texaco pumps that burn my hands. I've done 4,500 miles on it now, averaging 22-23mpg on gas which I'm quite pleased with, I go fast everywhere now you see. LOL.
There's a worthwhile upgrade for the rear disc calipers to touring (estate) spec, with slightly larger pistons which may be of interest to you depending on where your setup came from. My handbrake fell apart recently, but the rebuild kit from the dealer was cheap, and gsf handbrake shoes cheaper still!
Have you got the front brakes and struts sorted? I've got some 325i front calipers and practically new ferodo pads in need of a home.
I said:
CHR1S1990
Post Thu Nov 26, 2009 10:10 pm
couldnt agree more, lol yeah my gas vavle is on the pumper at the back so i undo it with my foot so i dont burn myself! it looks comical..but cool..lol totally agree! i never even sweat my mpg anymore, it fluctuates between 24.7 and 25.0 depending on how i drive!
yeah id be totally interested! not actually quite sure what the donor was, should have the beam and arms by tuesday, just ordered new bushes, pipes and caliper parts ready after powdercoating.
front 51mm struts are on the list too, are the front disks on 51mm struts bigger than the 45mm? or ar the just vented as opposed to solid? not to clued up on this section..
CHR1S1990
Post Thu Nov 26, 2009 10:15 pm
e301988325i wrote:I've seen your courier question, I believe you don't require the track rods, you use the E30 ones, check elsewhere first though, mine's been on a while I've forgotton. You do want the E46 steering rack boots IIRC. You also won't need the steering column coupling attached to it.
thanks for the advice! still waiting for them to reply to me at all lol..so i will see what they say. cheers
e301988325i
Post Fri Nov 27, 2009 2:24 pm
I'm fairly sure the diamter is the same, 260mm. have a measure of the rear caliper pistons when you get them.
I said:
**BANNED**
Post Fri Nov 27, 2009 2:51 pm
Difference in rear calipers is between ABS and non-ABS as far as I can determine...my touring (ABS)required a different rear caliper to my project cabbie,which is non-ABS...
Youth is wasted on the young.
Dave_M3
Post Fri Nov 27, 2009 4:24 pm
If you see any more Sport racks floating about let me know...
Looking for 3 of them :mad:
N00b
Post Fri Nov 27, 2009 5:36 pm
Dave_M3 wrote:If you see any more Sport racks floating about let me know...
How much do these racks tend to go for?
Dave_M3
Post Fri Nov 27, 2009 7:38 pm
£60 going from some of the posts above :D
But e46 racks can go for anywhere between 50 and 200 quid depending on who is selling them.
N00b
Post Fri Nov 27, 2009 7:40 pm
Dave_M3 wrote:£60 going from some of the posts above :D
I want to change the rack in my touring and do the solid guibo thing while I'm there. I think the 2.7 rack might be a little bit twitchy for my liking so something around 3.0 turns would be a better option.
Hmmm.
Dave_M3
Post Fri Nov 27, 2009 10:10 pm
The E46 rack doesn't need any guibo so saves the cost of getting one made up :wink:
N00b
Post Sat Nov 28, 2009 12:15 am
Dave_M3 wrote:The E46 rack doesn't need any guibo so saves the cost of getting one made up :wink:
OH?
Now this is getting interesting.
Dave_M3
Post Sat Nov 28, 2009 12:41 am
The pinion is alittle longer on the E46 rack than it is on the E36 one so you can just take apart the U-Js and bolt them solid to eachother hence removing the gay rubber guibo.
N00b
Post Sat Nov 28, 2009 10:19 am
Dave_M3 wrote:The pinion is alittle longer on the E46 rack than it is on the E36 one so you can just take apart the U-Js and bolt them solid to eachother hence removing the gay rubber guibo.
I like the sound of this. It must also mean that it reduces any clearance issues for those who fit a later engine I suppose?
Dave_M3
Post Sat Nov 28, 2009 10:34 am
Yeah, makes a little bit more clearance on the M42 which is fine normally but any more is always a bonus.
Makes a good difference with an M20 but still not enough for an M50 or an S50 obviously.
N00b
Post Sat Nov 28, 2009 10:54 am
Dave_M3 wrote:Makes a good difference with an M20 but still not enough for an M50 or an S50, but this is obvious to anyone who knows more on the subject than N00b.
Fixed, lol.
Removing the guibo is a good thing, as it looks like the standard part is only there to absorb any NVH. Once you've decided to replace it with a solid guibo then it might as well not be there at all.
Dave_M3
Post Sat Nov 28, 2009 3:42 pm
:lol:
Well, you can only learn things by askign questions!
Yeah, I removed my guibo when I changed from the E36 rack to the E46 rack and the steering feels much nicer and feed-back is brilliant.
The guibo is there for absorbing vibration for the poncy execs that might have bought an E30 in the first place but I doubt any of us will mind it (even though there doesn't seem to be a noticeable increase in vibration in the steering wheel any way)
Other reason is the guibo is a shear point on the column in the event of a crash so the whole column doesn't push the steering wheel on top of you.
But to be honest, If you have a crash big enough to bend the car to the point that it shears the steering column, I think there'll be more things to be worrying about that the steering wheel moving alittle!
e301988325i
Post Sat Nov 28, 2009 4:51 pm
Hmmm.
If you read the thread you will see that there is no difference in the ratios of the racks, just extra movement on the e46 rack.
I said:
N00b
Post Sat Nov 28, 2009 9:48 pm
Hmmm.
Yeah I think I read that. Same number of turns but more lock.
Looks like I'm going to have to look out for one of these bad boys.
Dave_M3
Post Sat Nov 28, 2009 10:30 pm
There is no extra "quickness" in the E46 racks (apart from the Sport one) but the fact that the E46 racks are in generally far better condition at this stage compared to old E36 racks, the steering still feels much better with the E46 one.
I went from sloppy E30 rack in a 318iS
Then E36 rack from a 98 318iS
Then an E46 rack from a rear ended 02 318Ci with 50K on the clock
then to slightly improve things again with a 370mm steering wheel
Soon I'll be changing that again though to a Sport rack when I put in my shiny new subframe and engine mounts :D
e301988325i
Post Sun Nov 29, 2009 9:16 am
The sport rack is still no quicker, just has added weighting for a better 'feel', well worth it though.
I said:
