Idle Control valve
Rusty01
Thu Nov 12, 2009 12:25 pm
Hi,
Probably a stupid question, but Does the ICV affect the idle when cold. My 316 M40 messes about like mad when its cold then seems to sort it self out when its warmed up.
Also can anybody explain what happens to an M40 engine when sarted cold is there a cold start injector etc.
Any help would be appreciated
Russ
spp320i
Thu Nov 12, 2009 12:31 pm
yes, the ICV affects the idle when cold. If it's messing about, try giving it a good clean out with carb cleaner - you should be able to hear the insides click round if you give it a shake.
Can't help with the info on a cold start injector though!
Rusty01
Thu Nov 12, 2009 1:38 pm
Cheers, I wil give it a go at the weekend
sihooker
Thu Nov 12, 2009 1:49 pm
The M40 doesn't have a cold start injector...less to go wrong! :D
Rusty01
Thu Nov 12, 2009 1:54 pm
Thats a bugger, I was hoping that might be a reason :) . I have changed the cold start sensor, but it still don`t want to idle when its cold :?
sihooker
Thu Nov 12, 2009 2:12 pm
This is such a common problem with these engines, and i know from experience!
I'm NOT suggesting you do this, but i broke into my AFM and adjusted the spring setting on the flap...but this was after checking and replacing everything first. It seems to have worked though :D
I've just looked for the site that covers this, but i cant find it! :(
Rusty01
Thu Nov 12, 2009 4:48 pm
No worries, I will have a hunt around and see what I can find. Cheers for the advice
engine_ear
Thu Nov 12, 2009 10:48 pm
Check the air hose from the ICV to the main air hose isn't cracked. I was having similar issues til I replaced mine.
1990 318i Touring
The red shed...
