m50 cam options?
320ise
what would be the best set of cams for an m50? already have chip bbtb s/s exhaust CAI i think a set of cams would finish the job nicely!
E34 ///M5 THE BEST BMW EVER BUILT?
Schrick cams are the tits, but, they will cost you more than the car is worth
FormerMember
One mod is to swap intake cam to exhaust cam and buy "wilder" intake cam..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
e301988325i
does that mean that two intake cams would be an improvement?Jonsku wrote:One mod is to swap intake cam to exhaust cam and buy "wilder" intake cam..
doesn't the s50 b30 provide upgraded cams for the m50?
I said:
e30topless said:
lock the wife in there
FormerMember
Yes, what i mean is that intake-cam profile is "wilder" than exhaust cams, so swapping it to exhaust cam and bying "wilder" cam to intake cam livens up your engine.e301988325i wrote:does that mean that two intake cams would be an improvement?Jonsku wrote:One mod is to swap intake cam to exhaust cam and buy "wilder" intake cam..
I'm not sure if S50 cams are straight bolt-on to M50, but definitely they're improvement.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
e301988325i
So, yes two intake cams in one engine would be better!!!
I said:
FormerMember
No, it's not improvement to put two intake-cams on the engine. When you swap intake cam to exhaust cam you need to bolt "wilder" intake cam than the original, otherwise it won't work well.e301988325i wrote:So, yes two intake cams in one engine would be better!!!
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
- Homo Hair
S52B30 or S52B32e301988325i wrote:does that mean that two intake cams would be an improvement?Jonsku wrote:One mod is to swap intake cam to exhaust cam and buy "wilder" intake cam..
Waste of time messing with inlet cams, and this can only be done on a Non Vanos engine. You are better off advancing the inlet but it will affect the idle and make it sound like a tractor. Unless you have a pair of performance cams there is no point changing them
Dave_M3
Or if you have S52 cams sitting there that cost you nothing or very little.
S52 cams = performance cams surely?
Dave_M3
Well yeah but for fraction of the cost of aftermarket performance cams
